My speed control doesn't work maybe? Not sure how to use speed control
I have a couple different issues I'm confused about like my speed control not sure how to use, i also have a anti lock failure bulb and failure low coolant level circut 1 failure and circuit 2 failure low brake pressure, the circuit i have no ideas or anti lock or bulb failure?
The cruise control is turned on by the paddle lever on the right side of the instrument panel. Pull back to turn on, and there's a small square button next to it to engage. Have you checked your fluids? Are the dash lights correct? I have corrected an anti lock light by bleeding the brakes and getting the new fluid in there. It sounds like you're saying that your fuse light is on too? You just need to isolate what isn't working and try changing those fuses but there is likely a reason they blew. Hope this helps.
Hi Nate,
Welcome to the Jaguar Forums! It's great to have you with us!
The first thing we need to know is the year, model and engine displacement of your Jaguar. That will help us give you more accurate replies.
Secondly, please visit the New Member Area - Intro a MUST and post a required introduction so we can learn more about you and your Jaguar and give you a proper welcome.
Also, please read the important information at this post:
New Members - A Must Read if You Have Just Signed Up
Cheers,
Don
Cheers,
Don
