Mystery switch
Received 13,379 Likes
Hi 92Jag,
Are you saying you do have the security system switch, and the mystery switch is a second switch under the center console arm rest? The only thing I can think of would be a switch for an aftermarket device such as a radar detector. Can you post a photo of the switch?
Cheers,
Don
If it's not a secondary/aftermarket security system then perhaps an ignition isolation switch fitted by a PO to make it harder for anyone to steal the vehicle?
Thanks to everyone who had suggestions on this. It proved to be the valet switch on the security system. The security system supplemental pamphlet said there was a valet switch and the Jaguar dealer would tell me where it was, so I probably should have figured that out. The lady who sold it to me said the remote was the only way to operate the security system, so that kind of threw me off the trail of security system switches. I probably never would have figured it out without your help, unless I turned it on when the alarm was armed which then sets the alarm off.
Thanks again I really appreciate the help.
93SB (02-28-2015)
I had a 1992 that had the VALET switch installed on the underside on the steering column cowl. Putting the switch in one position has the annoying effect of having the security sounder activated every time you open the door or operate the ignition key.
Putting the switch in the other just kept it QUIET!!!!!!!!!!!
bob gauff
bob gauff
goges
10-05-2015 04:53 PM
