Need HELP! motor swap!
RE: Need HELP! motor swap!
Greetings,
'96 engine will not fit, even a '94 is different. You have to go '90-'93 for the same short block and head. Make sure the injectors are the same (check color band), or swap them back from the bad engine. I can build you a head if you need one. If the car is already off the road, you can just as well have a local machine shop go through it.
abonano
25
09-25-2015 10:43 AM
