I just discovered a huge vacuum leak on my 1994 XJ6 and it seems that there is a huge crack in one of the crankcase breather hoses.
I looked on the Jaguar Land Rover Classic parts website and I believe the part number for this hose is EAC7447 which naturally is NLA.
This hose is a very strange shape and the ends are two different sizes. One end (smaller end) fits over a hose nipple on the 90° elbow leading to the throttle body and the other end goes to some sort of electrical heater unit. I went to a local parts store that I know has a large selection of various hoses hoping that I would find something close enough to adapt to this application but nothing was even close.
Since most of these critical parts have been discontinued I don't know how we will keep our care on the road in the future. BTW, I also noticed that the corrugated hose that connects the larger end of the 90° intake elbow to the inlet of the throttle body is also NLA from Jaguar. I can see this being a critical thing when these start to fail in the future. crankcase breather hose diagram - item 6 is EAC7447 which is NLA. Mass air meter and throttle body elbow - item 7 EAC9552 is the elbow
My hose from 1994 looks like this:
The crack in the hose can be seen here: Big crack in hose
Nevermind, good news. I was able to find replacement hoses on ebay by searching for the Jaguar part number EAC7447
I ordered two of them just in case. I hope they are the right thing and fit when I receive them.
BTW, searching on ebay also shows the large corrugated hose EAC 6370 for the intake is also available from several sellers.
I guess the parts supply isn't so hopeless after all.
Yes, fortunately there are some more parts suppliers which can deliver what Jaguar can't. Even though I noticed that prices for some parts have increased significantly in the past 2 or 3 years.
In your case: since this is a 'solid' rubber part maybe it could be fixed by vulcanizing it, in case no replacement part is available
This is one really oily hose internally and if it has split, you could attempt vulcanizing it but I wish you luck with getting it clean enough. Easier to use two hoses and a union. That's what I did when mine split.
The URO corrugated hose from Rockauto, although a bit more light weight than the OEM is definitely the way to go if the air intake hose has deteriorated - and let's be fair, if you take it off for a annual TB cleanout/oil dump theres a pretty good chance it's less than perfect anymore, especially around those flanges.
I'd imagine even the Ultra-Power one would probably just fine also.
