New Owner 1994 XJ81 V12
For the inline 6
jagrepair.com/images/Electrical/Elect-Tech All2/94 XJS 4.0L Electrical.pdf
See page 19
And the V12
jagrepair.com/images/Electrical/Elect-Tech All2/94 XJS V12 Electrical.pdf
See page 19
The starter relay is in the same place on both versions
See page 11 , hit the + icon to magnify
The relay can be swapped with one of the same part # on the relay but it must click with your finger on it
Editing
See page 19
And the V12
See page 19
Editing
Jmains123 (09-29-2022)
Someone recently labeled the fuses in the PDF file below at the very bottom
On my computer I attempted to make you a pic but the fuse labels did not come through
You can double click on the pic to enlarge , put on a flash drive and the office supply store can print it off on a large paper and even laminate it
So you have some tools to work with , do you have a electrical meter ?
So a test point would be if you have power present at socket 86 of the starter relay with the key in the start position
This verifies somewhat the ignition switch
Second test point would be the socket 85 that it has resistance close to zero
Or reset the start inhibit switch and just try to start
Hi Jmains123
It could be 'The Fuseable Link' that needs pushing together
Its a very common problem if you've got No dash lights or She won't Crank and is also a very easy fix that just takes a few seconds!
No Crank or No Lights? Check that the Fuseable Link is Pushed Tightly Together This is very easy to disturb especially if you've just Changed the Battery!
