XJ40 ( XJ81 ) 1986 - 1994
New Owner 1994 XJ81 V12
Old 09-18-2022 | 07:02 PM
Parker 7's Avatar
Default New Owner 1994 XJ81 V12
For the inline 6
jagrepair.com/images/Electrical/Elect-Tech All2/94 XJS 4.0L Electrical.pdf
See page 19
And the V12
jagrepair.com/images/Electrical/Elect-Tech All2/94 XJS V12 Electrical.pdf
See page 19
The starter relay is in the same place on both versions
See page 11 , hit the + icon to magnify
The relay can be swapped with one of the same part # on the relay but it must click with your finger on it
Editing
Jmains123 (09-29-2022)
Old 09-24-2022 | 11:00 AM
Parker 7's Avatar
Someone recently labeled the fuses in the PDF file below at the very bottom
On my computer I attempted to make you a pic but the fuse labels did not come through
You can double click on the pic to enlarge , put on a flash drive and the office supply store can print it off on a large paper and even laminate it
So you have some tools to work with , do you have a electrical meter ?
Old 09-24-2022 | 11:25 AM
Parker 7's Avatar
Old 09-24-2022 | 04:03 PM
Parker 7's Avatar
So a test point would be if you have power present at socket 86 of the starter relay with the key in the start position
This verifies somewhat the ignition switch
Second test point would be the socket 85 that it has resistance close to zero
Or reset the start inhibit switch and just try to start
Old 09-28-2022 | 03:06 PM
Jmains123's Avatar
Default New owner of 1994 jaguar v12
Hello i am new here so sorry about all the questions. i just recently got the car and it doesnt crank or start. i also have no dash lights or gauges pls help me
Old 09-28-2022 | 03:12 PM
ptjs1's Avatar
Start by measuring the voltage at the battery terminals in the boot.
Then restest the voltage at the battery terminals on the front bulkhead.
Paul
Old 09-28-2022 | 04:36 PM
Jmains123's Avatar
im sorry what do you mean by front bulk head
Old 09-28-2022 | 05:15 PM
equiprx's Avatar
I think his meaning if find a positive source of power, like the fuse or relay panel in the engine bay.
Old 09-28-2022 | 05:23 PM
Jmains123's Avatar
ok theres a red positve post in the engine bay what am i looking for
Old 09-28-2022 | 05:37 PM
jal1234's Avatar
He's talking about the two direct feed points from the battery, one on each side of the firewall. A little hard to see, as they are covered by black rubber boots.
Old 09-28-2022 | 05:49 PM
Jmains123's Avatar
Im stuck in a rut, battery is brand new and is giving good power but i have no power to my dash no gauges show up
Also whats the wire coming off the positve cable that goes to the battery
how much volts should the starter relay read in the on postion.
Old 09-28-2022 | 06:19 PM
ptjs1's Avatar
Have you measured the voltage at the bulkhead terminals rather than at the battery terminals?
Old 09-28-2022 | 06:21 PM
ptjs1's Avatar
Apols, it's called the firewall in the US.
There are +ve & -ve terminals on the firewall. You need to know that you have full voltage at those terminals for anything to work.
Paul
Old 09-28-2022 | 06:24 PM
Jmains123's Avatar
im sorry i can not seem to find it
Old 09-28-2022 | 06:32 PM
Jmains123's Avatar
i found jt and its the same as the battery
Old 09-28-2022 | 06:39 PM
Jmains123's Avatar
there the same as the battery whats next to check and thank you
Old 09-28-2022 | 06:46 PM
Jmains123's Avatar
whats next to check
Old 09-28-2022 | 06:49 PM
Jmains123's Avatar
i just did and there the same the battery and them
Old 09-28-2022 | 07:02 PM
orangeblossom's Avatar
Hi Jmains123
It could be 'The Fuseable Link' that needs pushing together
Its a very common problem if you've got No dash lights or She won't Crank and is also a very easy fix that just takes a few seconds!
No Crank or No Lights? Check that the Fuseable Link is Pushed Tightly Together This is very easy to disturb especially if you've just Changed the Battery!
Old 09-28-2022 | 07:04 PM
Jmains123's Avatar
do you happen to have pictures i have the cable to just nothing to put it to
Quick Reply: New Owner 1994 XJ81 V12
