new problem not starting not cranking no lights just a beep
after repair almost everything in my car: fuel pump, alternator, transmission relay (causes limp home mode), fuel pump relay, etc etc. i found that this morning when i went to put the key the car did not start.
symptoms:
1-when key is inserted in the door the central locking system is not working
2- just a beep, no lights on the dashboard, no nothing.
3- looks like NO battery at all, will check and post the results.
Martin
symptoms:
Martin
symptoms:
Martin
symptoms:
Martin
2.did you reconnect ground from engine block
3. have parts available that work dimsum29@hotmail.com 954 298 5602
alt starter , etc ,
1964Daimler
09-02-2015 11:41 PM
