No Spark
mrtalk:
Even if the pump is running, it might not be a bad idea to confirm that you have full pressure at the fuel rail with a gauge. If your issue is spark related, the full tune up is probably in order anyway: plugs, wires, cap & rotor, coil, HT lead from coil. There is also an ignition amplifier that could be flaky. Maybe I'm being excessive... Scott
LilaJagHubby
10-06-2015 02:56 AM
