no start issue
I am diagnosing a crank, no start issue. The crank sensor checked ok. Fuel pressure checks ok. The injectors are working because I definitely smell fuel, as if it were flooding. I have a weak/no spark. I am ohm'ing the coil which is reading higher than what is the norm....8.9 on the 20k ohm scale, versus 6k ohm, which is what it is suppose to read, plus or minus 10%. Im also getting a .9 ohm reading between the positive and negative coil terminals, where it is suppose to be .5 ohms.
I am getting 12V at the positive coil terminal which tells me the ignition relay and ignition amplifier/module are good. Not to mention the amplifier is about a year old.
Any thoughts?? Im probably going to replace the coil.
No check engine light.
Thanks,
Thanks,
MilitaryMan33
08-15-2014 07:24 PM
WinterJag
05-18-2012 12:38 PM
SeldomJAG
10-11-2011 12:21 PM
Jpetreeko
05-20-2011 07:14 AM
