Noise from solenoid valves.
Guest
Posts: n/a
Hello!
I´m new here, have bought my first Jag as a project, and work is in progress.
I have a little problem though. The oil tank for hydraulics was almost emty, and i heard a tapping sound from the solenoids on the drivers side. I have now filled it with new oil (some green stuff) but it still sounds, but it dissapears when the engine idles in 10-15 minutes. It also dissapears when i open the bleeder nipple on the solenoidvalves, but it comes back.
Is there some special procedure i must follow to bleed the system or what can i do?
I´m thankful for all help.
The car is a ´91 XJ40 with 4 litre engine
Problem is solved!
Problem is solved!
baskervillema
10-01-2015 06:43 PM
