Noisy lifter and Synthetic oil
Just purchased a Beautiful xj6 1991 with 57k. One of the small problems is noisy lifter! Was told that they arehydraulic and cannot be adjusted. Then told mechanic after he recommended an oil aditive that I had synthetic oil - he said that was not good and may well be reason. Told me to go to normal oil 20-50 and add the pint of the additive.
Opinions on that?
ALSO how is door seal installed? Glued ? or . I need to R/R mine, already have new sills on the way.
Thank you
Opinions on that?
Thank you
Thank you but if nor glued in how do you go about changing them (after removing sill plate) Thanks.
Does have synthetic oil.
Ordered cam cover gasket because I was going to "adjust" lifters bUT now I know I cannot! Was quoted $ 1,100.00 by Jag dealer to do job? Fair price?
TY
Woznaldo
09-26-2015 11:02 AM
