O2sensor
Hey. Ff 44 is oxygen sensor rich or lean. This can mean a vacuum leak making it lean, or a leaky injector making it rich- which seems unlikely. Go over your motor and check all the vacuum hoses. If your car is running fine and all you have is the code, it's probably the sensor. If you have uneven idle - surging or stumbling you likely have a vacuum leak.
