Oil cooler bypass
Oil cooler bypass
The oil cooler lines on my 1990 XJ6 were leaking badly, so I've purchased an oil manifold from PartsBin. Removal of the oil cooler lines has been easy, and installing the manifold was no problem...except that the stud is not long enough for the original lock nut. Would a thinner plain nut and some Loctite be okay?
Replace the stud with the longer one.
Remove the stud and use a bolt of the appropriate length.
Cheers,
