Oil leak above distributor 1990 XJ40 4.0L
I pressure washed my engine and engine bay and used compressed air to dry it out.
The car starts and runs great but after the cleaning, I now have an oil leak above the distributor.
I have been reading posts about an upgraded cylinder head gasket that is available to repair this issue.
For those who have done theirs, Do you remember the part # for the upgraded gasket? and do I have TTY cylinder head bolts?
Part #s for the upgraded Cylinder head gasket and bolt kit will be greatly appreciated.
I'm sure you cannot buy the old design Head Gasket anymore unless it is NOS gasket from 25 years ago.
I have used the head bolts a second time but I have never reused TWICE deemed acceptable by Jaguar.
I had one snap off in the block/head during final torque. I managed to use epoxy to glue the bolt together to extract it and install another bolt so I did not have to remove the head again.
bob
bob
Don B (07-08-2018)
Received 13,425 Likes
Jagbits head gasket set: https://www.jagbits.com/product/JLM11088-X.html
Cylinder head bolts: https://www.jagbits.com/product/EBC1771-SET.html
Jagbits 10% discount code JAGFORUMS-10%
jar
02-28-2012 11:05 PM
