Oil Pressure ?
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
1993 XJ6, 128000mi, Drives nice, no stalling, recent Oil &
Filter change, The Oil Pressure while driving is at 4, When
at idle the pressure gauge drops to just above 0, The Oil
light Might go on momentarily, but only once in a while, This car has been sitting for a couple years, started regularly ???
Jim
Jim
shoeboy (11-06-2011)
Received 2,263 Likes
You could try changing brands or upping the base weight from the 10 of the 10W60 to 15 or 20. Within a API rating grade, various brands can meet the grade but still be considered thick or thin for that grade. 20W50 Castrol conventional, 15W40 Castrol Diesel conventional or 15W40 Shell Rotella T5 conventional.
Jim
Jim
I personally wouldn't be a fan of using a heavy weight oil, the AJ6 just never really had any oil pressure/delivery problems.
Cheers,
I've also had the transducer issue - but in my case - pressure went to 0 and the light came on. I found the kits fairly readily available from Rock/Amazon/Ebay on the order of $50. Not sure if it is the same resistor value for the earlier model or not though. According to the TSB...one should reprogram the X300 IP after installation, but my needle goes to very near the middle of the guage, so for me, it is ok. Just be aware, you are replacing the transducer with an 8 psi pressure switch.
For the XJ40, the part just superseded to the kit in the parts catalog, the X300 got the Tech Bulletin.
Just want everyone to be clear.
Cheers,
There may not be anything wrong at all, actually. The original gauge transducers were notoriously erratic, and showed low pressure when there wasn't low pressure. Ultimately Jaguar came out with a kit to replace the transmitter with the one the X300 used, and added a link lead that contained a resistor. That was part number JLM20791. I don't think the kit is available anymore, so the best bet would be to get the LNA5642CA transmitter and see if the LMD3325BA link lead is still available. If it's not available, post back and I'll try to find out what the resistance was so it can be duplicated.
Cheers,
Cheers,
Could this fix be applied to the 1988 Jaguar if the oil presure is also dropping intermittenly...I've been driving my car this way for over a year
![Icon Rally](https://www.jaguarforums.com/forum/images/smilies/icon_rally.gif)
![Icon Denk](https://www.jaguarforums.com/forum/images/smilies/icon_denk.gif)
I know there are a couple of industrious chaps here on the forum that have switched out a 1988-89 instrument pack for a 1990; and I don't recall them saying they changed the transducers. So you might be able use the switch and resistor. If it were mine, I'd just use the original part.
Cheers,
The other thing you might want to try early on is to hook up another gauge to see what the oil pressure is. There is a chance that you got a bad oil filter. Years ago, I changed the oil filter in my Mercedes (using a name brand), drove about 250 miles, and the next time I cranked it the oil pressure was close to zero. I even took the valve cover off and confirmed this. Changed oil filter again without changing oil and everything was fine when I started it.
I use Castrol Edge Sport. 25-50 mineral oil in my '92 3.2 @ 260000 kilometres.
Some details.
• Gives low oil consumption.
• Excellent oil pressure at high temperatures.
• Excellent protection against wear. Protects radical cam profiles,
tappets and other highly stressed components.
• Resists viscosity breakdown at high temperatures giving higher
viscosity at extreme temperatures than traditional "straight 50"
oils.
• Synthetic components increase load-carrying characteristics for
crankshaft bearing protection in older technology street machines
and “big bore” competition engines.
• Formulated to give better cold start performance than traditional
"straight 50" oils.
• Race proven performance, including wins at Bathurst, Auscar
championships and Drag racing.
• Assists in maintaining optimum oil pressure in older cars.
• Complies with the Australian Motor Industry agreed phosphorous
limits for prolonged catalyst and oxygen sensor life.
• SAE 25W-50 APISG/CD. Incorporates full API SM detergent and
sludge control additive system.
Typical Characteristics
SAE RATING: 25W-50
KV @ 100C : 21
KV @ 40C : 212
cP @ -10C : 9,500MAX
HIGH TEMP
HIGH SHEAR VISCOSITY : 5.4
POUR POINT (C): -24
TBN: 8.0
API SERVICE RATING: SG/CD
Some details.
oils.
"straight 50" oils.
SAE RATING: 25W-50
KV @ 100C : 21
KV @ 40C : 212
HIGH TEMP
POUR POINT (C): -24
TBN: 8.0
Alldata has some info for the engine oil posted for the 1990 XJ-40.
ENGINE OIL
* CASTROL GTX
^Above -10°C (14°F)15W/40, 15W/50, 20W/40, 20W/50 [1] ^Between -20°C (-4°F) and 10°C (50°F)10W/30,40,50 [1] ^Below -10°C (14°F)5W/20, 5W/30, 5W/40 [1]
* preferred Brands
SPECIFICATIONS
[1] BLS.22.OL.02, BLS.22.OL.07, CCMC G3 (if not available use min. SF)
I have been using GTX 20/50 for a while now but in the dead winter I have changed to 10/40 as it can get to the - here early morning.
ENGINE OIL
* CASTROL GTX
* preferred Brands
SPECIFICATIONS
