Oil pressure fluctuations
Hi folks, 1988 XJ40 with the 3.6 here. When sitting in traffic, particularly pointed downhill I will see the oil pressure gauge drop down to zero at times, which is pretty frightening. Then when I get moving the oil pressure will bounce right back up where it belongs. Oil level is good, just had the oil changed and I just checked the level again.
Sensor problems, natural fluctuations, oil starvation to the sensor when sitting, any ideas what is going on? I really don't like seeing my oil pressure drop since I don't need a blown engine.
No need to worry, this is a well known issue with the sender unit ..your oil pressure is probably just fine.
This thread has all the information you need to fix it:
https://www.jaguarforums.com/forum/x...sender-133621/
Larry
Larry
The following 3 users liked this post by Lawrence:
Good luck
Larry
Don B (02-26-2018)
