XJ40 ( XJ81 ) 1986 - 1994
Paint Repair
Old 03-12-2017, 08:42 PM
Roger95's Avatar
Default Paint Repair
I have to repair some paint on all doors of my '90 U.S. spec Majestic. The color code is CF4 - Regency Red Metallic polyurethane base coat clear coat.
Does anyone have any suggestions on how to approach this? I would prefer to use my air brush as I have several small areas to repair.
Thanks,
Roger
Old 03-13-2017, 10:36 AM
Lawrence's Avatar
Received 1,871 Likes on 1,192 Posts
HI I went through this some time ago, here's the old thread from the archive:
https://www.jaguarforums.com/forum/x...p-paint-81913/
Don B (03-13-2017)
Old 03-13-2017, 01:35 PM
Roger95's Avatar
Thank you Lawrence!
Old 03-13-2017, 07:47 PM
Roger95's Avatar
I have rattle cans of urethane (acrylic) good color match and clear but the clear yellows as soon as it's sprayed on. I'll buy a small quantity of 2 part color and clear.
Old 03-13-2017, 09:27 PM
Received 13,464 Likes on 6,635 Posts
I've had good success with the clearcoat product from automotivetouchup.com, which is an acrylic lacquer. It has worked well on wheels and electric guitars I have refinished and I haven't noticed it yellowing at all. It produces a factory-level gloss right out of the can, but also responds well to wet sanding to 2000 or 3000 grit and then bringing to a mirror gloss with polishing compound.
Click on the image to go to the site:
They also have a 2K urethane clearcoat that I intend to try the next time I refinish wheels.
Typical disclaimers, no affiliation, etc.
Cheers,
Don
Old 03-14-2017, 12:29 PM
Roger95's Avatar
Thanks I may buy a can. Going to stop by my local parts store and buy some supplies and check out what they have for clear.
