Please help. Can't figure it out
i have a 1991 xj40. idles fine but falls on its face when i give it gas. i have changed spark plugs, wires,coil,fuel pump, fuel filter, MAF controller,and the crankshaft position sensor. the compression is good on all cylinders. the cats are not blocked. the distributor rotor is aligned... i'm at a loss i have no idea what to do next other then get rid of the car and thats not what i want to do.
Sounds horribly like a TPS (Throttle Position Sensor) going bad, located on the underside of the throttle body/housing.
They do fill up with gunk via the throttle spindle. Sometimes a good clean with solvent will give them new life, sometimes not.
It is about all you have NOT touched as per your original post??.
Maybe, coz if it is giving strange signals to the main ECU, fueling etc will be all amuck.
I do know that on my V12's when they went AWOL, the engine overfuelled like crazy on the XJ-S, and just did odd stuff on the XJ12. The throttle switch (old school) on the Pre HE just did its own thing at whatever time it wanted, but the engine was bogging down bad, however that system is waaaaaaay different to what you got.
I am just saying that this sensor/switch is a priority signal provider to the ECU, and in all my years, if it is NOT giving a "smooth steady" signal to the ECU, that same ECU gets confused, and does equally strange things, mainly to fuel/injector operation.
That's a pretty old car you have there, so it could benefit by the fuel injectors being checked out individually and cleaned. If the spark plugs are black with soot, there must be too much fuel going in or something. Fuel injection specialists normally are able to clean and rebuild injectors, especially those of 1991; maybe not those on later models.
Other thing is the two biggest inputs to fuel injector pulses from the ECU is engine temperature and mass air flow; the other inputs are trimmer inputs
It's a case of elimination, I'm afraid. I would suggest checking out the coolant temperature transmitter. These can fail but the thermistor resistance has to be checked at cold and when hot against the correct values. It's DIYable, but a bit awkward as you need an AVO meter. If this is OK, I would be looking at each of the injectors. All this assumes your fuel rail pressure is OK
Well i cleaned it out , nasty. couldn't even blow air throuh it. still falling on her face. if the coolant temperature transmitter was bad wouldn't throw a code? yeah. At this point i'm almost willing to try anything. if rubbing her on the back fender and telling her how pretty she is would work i'd do that.
Believe me, I know how frustrating these kind of problems can be. I had the model before yours, the XJ6 Series 3 which had EFI, but this was Bosch L-Jetronic analogue technology - no faults codes or anything. Maybe it was better this way, as I sorted it out in the end, but it took a long time. If the fuel is there, and the spark is there at the right time, it has to run !
