Possible oil leak, general tidbits...
Just a couple of things to watch out for...oil filler cap....rubber o-ring on it. Replace, will cure some leaks, and car will idle better.
Replaced your rocker cover gaskets couple years ago? Seeing leaks at the top of the screws ? Try it they will be loose. 25nm torque I believe.
Brake pedal rubber worn? New ones cheap...and easy to put on!
No dash lights? I put up with it for years fiddling around then replaced the switch with good second hand. Bingo...dash lights!! Checked the back of the instrument panel had a couple of globes out as well.
Mick from melbourne AU
garethashenden (03-04-2022)
orangeblossom
02-28-2016 04:35 PM
