Power steering reservoir port broken...
Do you have SLS rear suspension?
If you DO NOT have SLS then you just remove the pump on the front of the engine, remove ALL the valve block components and hoses, block the port off and you only need the PAS return to the reservoir!!
Get a single reservoir-to-pump hose and discard the hose with the Y in it.
You can use a 1988/89 PAS reservoir!!! Put DEXRON in the reservoir and go on with your life.
bob
bob
The SLS rear level sensor is UNPLUGGED. The springs are SLS springs (red stripe).
The rear suspension is NOT working as installed at this time. I imagine that if the rear dampers have not been replaced with regular dampers, then you must have a very 'bouncy' rear suspension.
You might want to consider performing the SLS DELETE.
Hundreds of threads and info for a few decades.
bob
bob
dhatfield12 (10-17-2016)
hakunti
10-22-2016 08:09 AM
MiniFarm
10-21-2016 02:50 AM
rf69
10-14-2016 03:47 PM
FS[Western US]: Selling my Ceramic Brake Pad Set - EBC Red
GrtShrk
10-13-2016 09:46 AM
