radio wiring
You will need to modify the existing harness and it's a little tricky working out which wires go where but to start you off....
1989 Jaguar XJ40Car Stereo Installation Diagram;
Car Radio Battery Constant 12v+ Wire: Brown/White
Car Radio Accessory Switched 12v+ Wire: Green/Orange
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Power Antenna Trigger Wire: Green
Car Stereo Amp Turn-On Trigger Wire: N/A
Car Stereo Amplifier Location: Behind the Glove Box
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Red/White
Left Front Speaker Negative Wire (-): Red/Green
Right Front Speaker Positive Wire (+): Pink/White
Right Front Speaker Negative Wire (-): Pink/Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Red/Brown
Left Rear Speaker Negative Wire (-): Red/Green
Right Rear Speaker Positive Wire (+): Pink/Yellow
Right Rear Speaker Negative Wire (-): Pink/Green
Hey, im having a problem with my factory radio. Whenever I drive and sometimes I might hit a bump and the radio sound will go real low or sometimes go completely out and I have to tap the side of the radio and it will come back on but will be low and then get loud. Whenever I turn the volume past 29 the sound get lower. I need help on what the problem could be please help.
I'm a little confused about the red/green on this diagram and the double red/green and single red/green wires i have coming out.
The diagram shows red/green being shared between the left front and rear speakers w/ direct connection. I'm guess this explains the double red/green wires that are combined into one. But i also have a single red/green. What is this? The diagram shows a red/green between the front and rear right speakers, but not directly to the deck.
I'd like to understand what's going on. Thanks!
Received 12,932 Likes
Hi jahlack,
If the schematic you posted is from the Haynes manual, I would recommend that you download the Jaguar Electrical Guide for your 1991 XJ6, which will probably be more accurate. You can download the manual for free at the link below, courtesy of our forum member Gus:
http://jagrepair.com/images/Electric...Electrical.pdf
I'm not sure if I understand your question, but as I read the schematic you posted, the Left Front and Left Rear speakers have separate positive (+) wires, but their negative (-) wires are both Red/Green, and both splice to a single Red/Green wire to complete the circuit to the head unit.
The right side is similar, but the two separate Red/Green wires from the speakers splice to a single Pink/ Light Green wire to complete the circuit to the head unit.
If I didn't understand your question, please let me know.
Cheers,
Don
Cheers,
Don
So that spliced Red/Green is (+), i had it written down as (-) from what i could trace to my speaker. I should look again.
I'm looking at the stock connector, this is what it looks like and what i can gather from the diagrams, please correct me where i got it wrong:
Connector Lead Row 1
- Red/Purple: Left Bass (+ or -?)
- Red/Lt Green: Left Bass (+ or -?)
- Lt Green/Black: Antenna Logic
- Red/Green (spliced): Left Front & Rear (-)
- Red/Brown: Left Rear (+) diagram shows red/brown for both Right Front & Left Rear?
- Red/White: Left Front (+)
Connector Lead Row 2
- Pink/Orange: Right Bass (+ or -?)
- Pink/Red: Right Bass (+ or -?)
- Red/Green: ???
- Brown/White: Hot
- Lt Green/Orange: Radio Relay
- Pink/Lt Green (spliced): Right Front & Rear (-)
- Pink/Yellow: Right Rear (+)
- Pink/White: ???
- Red/Green: ???
- Brown/White: Hot
- Pink/White: ???
'05 Gold XJ8L VDP
09-18-2015 07:15 AM
