Rear Driver side window in an 88
Wehad the same problem on ours, try just taking off the door panaling. We took ours off and found out some dumbass mechanic worked on the door handle under the panaling, but unplugged a wire for the window, so it was a simple plug it in solution and our window worked.
Guest
Posts: n/a
Okay so i sorta removed the door panel and noticed that the bottom of the motor looked corroded, so I suspect that water ran down the window and into the regulator, eventually shorting it out or i don't know what. Is there a write up on removing the rear driverside window regulator?
99xk8guy
06-05-2023 06:28 AM
