Rear Ends.
rear 'n gear
What gear ratio do you have now? If it the 3:54 the 4:11 will offer a noticeable difference. The cons are few. The engine will turn a few hundred RPM higher on the highway and you will likely see a slight decrease in fuel mileage. If you do mostly highway cruising it's not a great idea. If you do mostly lower speed city and boulevard driving it may offer a snappier driving experience.
jessiejames (01-10-2014)
where to find 4:11 rear end.
Motorcarman didn't know where to find a 4:11 rear end for a 94 xj6. Coventry West located in Ga. has them in stock. still not sure if I will change from stock rear end to 4:11. I want the bottom end but afraid of possible problems. Thanks for all the advise from everyone. Will keep you posted.
