rear hub noise LH side
Received 13,379 Likes
Hub disconnected from diff centre...isolated to inside the hub itself so wheel bearing. Happily I have just picked up a full diff from the wreckers that hub turns nice n smoothand have it off. My 91 though has a shield or locking thing covering the outer hub shaft....and the shaft doesnt seem to want to move. Any ideas on howto remove it?
Hi mickvic,
I'm having trouble following which parts you are describing. Maybe you could tell us part numbers on the following diagrams to help us understand where the problems are. I can't envision the shield you are describing off the top of my head. Can you post a photo?
Differential Assembly:
Differential internals, including the output shafts (Part 10):
Half-Shaft with U-Joints:
Rear Hub & Hub Carrier:
Cheers,
Don
Cheers,
Don
93SB (07-04-2022)
I believe this is what my 15 XF 5.0l sc is doing now. I hear an annoying hum or howl at certain speeds but only in drive or sport. Goes away when rolling at that speed in neutral. As soon as I turn to drive, it's back. Thoughts?
This is the forum for the XJ40 and XJ81, the XJ6 and XJ12 models from 1986 to 1994. Your 2015 XF 5.0L S/C is a very different machine.
My first recommendations would be to have the computers scanned for any diagnostic fault codes related to the differential lock motor or transmission. Also have the undercarriage inspected for problems such as oil leaking from the differential or transmission, a failing rear axle Constant Velocity joint, a perishing driveshaft flexible coupling, etc.
Depending on the mileage, it might also be prudent to have your transmission fluid, filter and electrical connector sleeve replaced, and the differential oil changed.
A failing wheel bearing could be another possible cause of your noise. If you have a local shop with the Chassis Ear system they can strap microphones to the diff and rear hubs to help identify the source of the noise.
Cheers,
Don
The following 2 users liked this post by Don B:
93SB (07-04-2022),
Exhauat Note Channel (07-04-2022)
innzane
09-02-2015 10:08 AM
Ian S 99
12-22-2008 11:05 AM
