Relay Module?
Relay Module?
My front passenger side low-beam headlight is out. -----> ([sm=smiley11.gif])([sm=smiley1.gif]) ([sm=smiley1.gif])([sm=smiley1.gif]) All four bulbs are good, so its not that. All the fuses are good also. If I switch high-beam, all four headlights work great. I ran out of ideas. As a quick fix, I even tried disconnecting the high-beam lights, so that when I switch to high-beams, only my low-beams remain lit. I quickly learned that when I switch to high-beams the low-beam lights get brigher, so I wasn't able to drive like that without unhappy oncoming drivers. Is there something I can do to see if its the relay module? I really don't feel like switching the two out, but if I must, I will.
zdrapec
09-25-2015 05:49 AM
