Remove lower control arm crossbrace?
Hello:
As the title implies, I am wondering if I could remove my lower control arm crossbrace. The car is currently supported by jackstands at the two front jacking points under the doors. I need to get at my oil sump to repair a leak that is just above the bar. My fear is that if I remove it, the control arms will move, making it incredibly difficult to re-install.
Thanks in advance.
Thanks in advance.
Don B (02-02-2021)
See the bar underneath all that JB Weld? There are castle nuts at each end. It is connected at the front of the lower control arms. I want to remove it so I can get rid of the JB weld and see what is going on. The two jack stands you see in the front are just there for backup. The two at the rear are on the jacking points.
If you 'get rid of the JB weld' you will likely need to remove the entire subframe or lift the engine. The oil will leak out of the hole that is patched with the epoxy?
Looks like you leave it alone or I see a replacement/repaired oil pan in your future.
You only need to remove the nuts, not the fulcrum bolt.
The following 4 users liked this post by motorcarman:
The following 2 users liked this post by GGG:
Don B (02-03-2021),
motorcarman (02-03-2021)
