rock crawler buggy project based on Jag V12 engine - need help
first of all sorry for my poor english
Last year I started an off road buggy (rock crawler) project based on a jaguar V12 6l and automatic transmission
I bought a complete car (4 doors XJ81 from 1993) and I removed the engine and gearbox. I took a lot of pictures with my phone, but unfortunately my mobile phone broke and I was unable to recover the pictures.
Now I am at the stage of mounting: cooling, fuel lines, brake lines and servo steering and to be honest I don't know exactly how to do it.
Now I need help with cooling lines:
1. engine oil lines are going just to the small radiator, while the gearbox oil lines are entering the small radiator and after going through the big (water/oil) radiator ?
2. near the oil dipstick is a water line that I don't know where exactly to connect
I really appreciate your help
thanks
thanks
Sorry, don't have a 12 but maybe studying this parts catalog will be of some help?
XJ6 & XJ12 from (V)667829 up to (V)708757 - Canada/USA | Jaguar Heritage Parts UK
Larry
Larry
Don B (03-17-2016)
thanks Lawrence; I searched that site, but the info is not complete
I found also a V12 6.0l manual, hopefully all models are the same.
So regarding the oil pipes is now clear, regarding the water circuit I will bypass the heater and connect directly the pipe near the oil dipstick to the radiator.
However I don't know how to connect the fuel lines. So far I connect the the fuel feed line and the fuel return line. But i saw that there is also a fuel vent line ? what is this and where should I connect ?
The fuel system on a 12, (if it's like the 6) would be part of a "closed" system which prevents venting fumes into the atmosphere, i.e. pollution control.
Venting (IIRC) would eventually lead back to the tank, but on the way would pass through a system of electrically controlled and vacuum valves with a carbon canister purging the fumes back into the intake - a completely closed system that uses a sealed (non-vented) fuel tank cap.
If you take a look at the site again it might illustrate the routing from the fuel tank.
I suppose if you're using a custom fuel tank with vented cap you would probably only need the supply and return lines?
No doubt most rock crawler builds out there probably aren't too concerned with things like EGR and pollution controls?![Icon Crackup](https://www.jaguarforums.com/forum/images/smilies/icon_crackup.gif)
Larry
Larry
Don B (03-17-2016)
![Embarrassment](https://www.jaguarforums.com/forum/images/smilies/redface.gif)
On the 6 one line runs from the canister > purge valve > intake manifold.
Bear in mind all I'm telling you is total guesswork on my part!
![Icon Playing](https://www.jaguarforums.com/forum/images/smilies/icon_playing.gif)
Larry
I managed to connect the engine cooling pipes to the radiator located in the Back and also the fuel lines.
Now I am looking at the steering reservoirs: there are 2 - 1 for the steering fluid, while the second is with a green fluid - is written Castrole levelling fluid CHSM05966.
This is the suspension leveling system? uses the same pump as for steering ?
how can I disconnect ? if I disconnect directly should not be a problem as the pump will run without the leveling fluid ?
I have one more question please
I have the master cylinder brake and the high pressure pump; master cylinder is having 3 connection + 1 from the reservoir to the pump.
I don't know how to connect the 3 connections - one should be Input from the pump and 2 are brake lines - front and back.
Also the pump should be electrically connected directly to the battery ?
thanks
thanks
sososs
XJ XJ12 ( X305 )
03-15-2016 02:13 PM
WTB[Canada]: Jaguar Car Cover for XJ6 XJR 95-97
snowball
02-29-2016 07:33 PM
