Rust On The Outside Of The Gas Tank
Hello Friends
Just read Mad Russian's post on rust inside of the gas tank. Didn't want to take over his thread.
So I was going to clean up the ground connections in the trunk. Luckily I did because I found moisture in the trunk with mold started to grow. I'm sure I'm able to save the carpets.
Notice some rust on the top of the gas tank. Pulled off the padding above the tank. So after I get rid of the rust is it a good idea to ruff up the tank with sandpaper and spay primer on it.
Also after reading about rust inside the tank. Should I pull out the feul pump and inspect the inside. Especially since it's all ready to go.
Thanks for your time.
On the 88, isn't the fuel pump outside the tank?
see this thread ..
https://www.jaguarforums.com/forum/x...t-start-39963/
Larry
see this thread ..
Larry
The following 3 users liked this post by Lawrence:
Hello Friends
Wewillbfree (05-23-2016)
Very important. Do not let those clamps fall on top of the rear differential. It will be a nightmare of monumental proportions trying to find them again. Use needle nose pliers or similar tool to pull them up and over the hose. It's not hard, just he careful.
Received 12,947 Likes
Wewillbefree,
On your '88 with the external fuel pump, all or most of the remaining fuel may be able to spill out when you disconnect the two hoses from the bottom of the tank, so you will want to siphon out as much as possible.
Mad_Russian's advice applies to the '90-'94 cars with the fuel pump inside the tank. On those cars, the fuel pump canister or module connects to both the outlet and return ports on the bottom of the tank, so only some of the fuel in the canister spills when you disconnect the hoses.
Cheers,
Don
Cheers,
Don
93SB (05-25-2016)
fward
07-24-2016 01:10 PM
