Setting initial distributor position
In thinking about my problem with the misfire I am getting because of the spark jumping on the top of my coil, I am wondering if I might have incorrectly set the distributor position when I re-installed it last summer after doing the headgasket on the car.
I'm wondering if at some advance condition the rotor is too far away from the the contact point inside the cap and this is causing a huge increase in the resistance in the electrical path to the spark plugs.
Can anyone describe the correct method to setting the position of the distributor when reinstalling it into the motor?
the car needs to be set at TDC on the compression stroke of cylinder one, there is a mark on the harmonic balance gear wheel and the body of the car to help indicate this
when in TDC the distributor rotor arm will point approximately to the 4 o'clock position , just before where the HT lead for cylinder number 1 would go to , also ensure the keyway in the dizzy cap is seated correctly ,
BB
BB
Don B (04-20-2020)
BB
BB
This is a large part so I am looking for a little more detail here.
Classic1275cc
12-28-2019 10:12 PM
