Side emblem removed
RE: Side emblem removed
I often buy parts from these stores, I've found the most variety and low prices between the three:
44.95 for one NEW emblem: http://www.jaggraveyard.com/product_...roducts_id=477
19.95 for two USED emblems: http://cgi.ebay.com/ebaymotors/JAGUA...spagenameZWD1V
24.95 for one NEW emblem: http://cgi.ebay.com/ebaymotors/JAGUA...mZ220071089039
If that's the case, then you can just adhere that part onto the chrome. Thing is, that part really isn't meant to come off, my guess is if you buy a new one, even a good used one, you can just remove that black part can it should have enough adhesion to stick to your car. Or you can just replace the whole part, I'm not entirely sure how to go about to do that.
Guest
Posts: n/a
One of my side emblems fell off of mine as well and it was a pain to find them. I got lucky and found a pair of them on Ebay Motors. Just keep looking and you'll get lucky. Or try jaggraveyard.com its got tons of used random parts. To hold them back on properly (since theyre metal) use a very strong plastic/metal emblem glue. the 3M brand carries a big red tube called Emblem Glue. It works perfectly. should be able to find it at any local autozone, carquest, pepboys, etc.
The side emblems should come with the chrome surround. It's sold as one piece. I should have a previously enjoyed (salvage unit) for $25. Use the 3M stuff to fix it in place. Jag/Jeep was dead on with that.
The rear emblems come in several choices, both are rectangular. The left side reads "Jaguar." The right side could read "XJ6," "Sovereign," or "XJ6 Vanden Plas." The "XJ6" and "Sovereign" are by far the most common.
