XJ40 ( XJ81 ) 1986 - 1994
Silly question
Old 08-07-2011 | 02:19 AM
devonia's Avatar
Default Silly question
Hello
I feel less than briliant asking this, but here goes...
On the compressor (right on top of the alternator) of my 1990 XJ40 (XJ6) I forgot where the conical washer on the pivot bolt goes.
Whereabouts... and which way does it point?
Thanks.
Regards
Richard
Old 08-07-2011 | 06:12 AM
Umm, it appears you are NEW here, WELCOME. Enjoy your time here, and most of all enjoy your car, there is NO going back now, trust me.
There is NO silly question.
I am not aware of a conical washer on these, but I might be wrong, only a split bush in the front lug of the mounting bracket, at the head end of the pivot bolt.
That pivot bolt has 2 flat washers, one under the head, and one under the spring washer on the nut end.
Also some of these have a pivot bolt with the washer as part of the head, so that flat washer is deleted.
If you are certain about that conical washer, look at the 2 lugs that the pivot bolt passes through. One of them will have the apposing conical shape to accomodate that washer, I think.
I am aware of these conical washers on the adjuster rods on S2 XJ6 alternator and a/c compressor.
Old 08-07-2011 | 05:28 PM
MidwestJag's Avatar
Richard:
Um, yeah... What Grant said. You could not have asked a silly question because I have absolutely no idea what you are talking about! [Not to say that non-silly questions are the only ones I understand... Actually, the opposite is probably true!] I trust you got it worked out. Welcome to the forum and glad that you are here.
happy motoring!
Scott
Forcedair1
02-19-2020 02:51 PM
kamiar
09-17-2015 07:30 PM
pnwrs2000
09-17-2015 05:04 PM
Andrew Fanshawe
09-14-2015 08:40 PM
DustysSon
09-13-2015 05:17 AM
Quick Reply: Silly question
