source of 1990 type Instrument Pack illumination lamps?
![Post](https://www.jaguarforums.com/forum/images/icons/icon1.gif)
I'm having trouble finding a source for the IP's filament lamps (warning or backlights).
The socket can be disassembled from the lamp, but I haven't found the correct lamp.
Anyone know of a part # and a retailer?
![](https://www.jaguarforums.com/forum/attachments/xj40-xj81-25/12354d1313391642-source-1990-type-instrument-pack-illumination-lamps-14v-t1-75-automotive-miniature-bulb.jpg)
this is the wrong part
Here is a photo I made of a disassembled hazard/warning lamp. The clips just slide up and out
allowing the lamp to be removed.
![](https://www.jaguarforums.com/forum/attachments/xj40-xj81-25/12373d1313428869-source-1990-type-instrument-pack-illumination-lamps-lamp_disassembly-red-.jpg)
Beside it is the lamp that the present day parts databases are claiming to be the replacement.
You can see it is too large, has wrong base, and the leads are not long enough.
o
o
Oubadah made a pretty detailed thread about what he did to his 95.
This might help you. Replacing Back Lights.
It's a good read anyhow, as you are interested in Auto Electronics.
I measured the resistance of one of my remaining good lamps and the meter read, about 10 ohms.
At 12V and if I'm doing the math correctly, these bad boys consume about 14 watts of power, each ?!
I've been looking for some kind of incandescent replacement on the Internet.
The closest I've come so far, is :
Lamp,filament,T1,5-5mm,min,wire ended,14V,37mA
(clickable thumbnail)
RS Stock No. 655-9592
![](https://www.jaguarforums.com/forum/attachments/xj40-xj81-25/12394d1313598299-source-1990-type-instrument-pack-illumination-lamps-r587068-10.jpg)
Manufacturer's Specs:
Current Rating 37 mA
Diameter 5.1mm
Lamp Base Wire Terminal
Lamp Size T1 1/2
Length 13.2 mm
Lens Colour Clear
Life Hours 5000h
Luminosity 0.2 mscp
Voltage Rating 14 V
They come in a pkg of 10 for $4.00 (0.40 each)
LEDs are starting to look as a better alternative here in the States.
o
![](https://www.jaguarforums.com/forum/attachments/xj40-xj81-25/12393d1313598299-source-1990-type-instrument-pack-illumination-lamps-m1428-01.jpg)
Diameter 5.1mm
Lamp Size T1 1/2
Length 13.2 mm
Lens Colour Clear
Life Hours 5000h
Luminosity 0.2 mscp
Voltage Rating 14 V
- The problem is they are "Temporarily out of stock, available for backorder".
- At 37 ma (0.444 w), I won't know how bright they are until I try them out.
- Also they will be shipped (if and when) from Australia. I have no problem with Australia but I just waited 6 weeks for a book to be delivered to my home from British Columbia (Canada).
o
Tony K
03-26-2024 01:53 PM
stanjag
08-30-2015 10:35 AM
