Speaker Replacement Plug and Play Suggestions
If you want true "plug and play" compatibility, believe it or not the OEM speakers are still available:
https://www.jaguarclassicparts.com/u...rs/loudspeaker
DBC6220
↳ LNA4140BA
But they aren't inexpensive. If someone has an aftermarket replacement that is a good match in impedance, power efficiency, power rating and mounting to the original, that would be good to know.
DBC6220
↳ LNA4140BA
supra-raleigh (07-09-2018)
aftermarket speakers
I replaced the speakers in my '92 a few years ago. These aren't the exact speakers that I have but I purchased a similar version and have not had any problems:
https://www.bestbuy.com/site/pioneer...?skuId=6065206
You have to remove the factory connector and the screw holes aren't perfectly aligned but it took about 10 minutes to install each one once the door panel was removed.
car5car
02-15-2016 07:03 AM
Elbert Jones
12-29-2012 07:41 PM
Thundercat
11-16-2011 05:24 PM
androulakis
01-22-2011 12:56 PM
