Speedometer Drama
Speedometer Drama
Hi all,
So since buying my 94 40, the speedometer hasn't worked, which in turn means the cruise, the odometer, and the ABS don't work either. I've replaced the wheel speed sensor, the ABS computer in the trunk, the fuse, and the relays (both the gray and yellow ABS ones). Still, nothing. Suggestions on the next step?
Everything on the dash works, except for the speedo. The "check engine" light is on, along with the "Anti-Lock" light too. TBH I haven't taken the gauge cluster out (mostly because I haven't the faintest idea how to since I don't see screws), but with the light on I'm thinking it's plugged in
Grasping at straws here, did you replace both rear wheel speed sensors?
It seems unlikely that a plug in the dash is loose, but I dont know the history, So it was just a thought. With the check engine light on there should be a code which you can access by turning the key to "on" and pushing the "vcm" button on the right side of the dash panel. I havent experienced the abs light YET so I can say on that. Wish I could help more....
The following 2 users liked this post by motorcarman:
blacktoothgrin (07-07-2023),
Don B (06-24-2023)
Your car has wheel speed sensors at all four wheels. The ABS could not function if it couldn't sense the speed of all four wheels independently. The most likely cause of your symptoms is either failure of one of the rear wheel speed sensors, a contaminated electrical connector, or a break in the wiring harness of one of those sensors. Inspect and clean the connectors and inspect the wiring harnesses carefully for any signs of damage. The sensors are handed (right and left) and are no longer available from Jaguar, so treat yours gently and repair the wiring harnesses if you find a broken wire.
Cheers,
Don
Thanks for the info! I've never seen where there were any other sensors aside from the front pass. I looked at the front driver's side as well and there's no wires going into the body like the pass side has. I'll take a look though.
And yes, Jaguar only keeps parts for 5 years (according to what a Jaguar service rep told me) so everything I've had to find is either used or "mortgage your house" expensive.
catmanboo (07-24-2023)
Cheers,
Don
The following 2 users liked this post by Don B:
motorcarman (06-25-2023),
TheDarkPhoenix (06-26-2023)
Hi all,
Hopefully your sorting out your problems doesn't cost too much , good luck!
