starter removal
One royal pita. On my 90 i removed the intake manifold.so as to get some working room.Then i used a 12 corner box end wrench which i bent to get the bolt from the backside of the bell housing (not a lot of room to work with).The other bolts come out easily.If and when i do it again i also would make the wrench longer for more leverage. I think this way is easier than having to do it as the hanes manual suggests.Also dont forget to disconect the ground from your battery.
aholbro1
08-05-2021 05:02 AM
1964Daimler
09-09-2015 11:28 AM
