Still having limp mode problems.
My 92 Sovereign with an auto trans is still going in to limp mode. I at first thought it felt like a fuel problem, as I had the code 44, but I haven't gotten that in a bit. Additionally the check engine light has stopped coming on. If I disconnect the battery for a day, the car runs and will get up to speed, but seems to not go over 2000 rpm. If I have the car in park or neutral, however the engine revs freely. It will eventually go into limp mode anyway.
I've only had the car for a short while, and it was priced to move. Didn't do a deep dive on the car or ask very many questions. After the fact however, I did ask the seller about the limping, and he seemed to not know anything about it, and this problem didn't come up until a couple weeks after we got the car.
Am I looking at a transmission problem? Should I still be looking at fuel delivery?
The following 2 users liked this post by Lawrence:
Don B (08-15-2019),
motorcarman (08-15-2019)
Received 13,203 Likes
On our '93 the most common cause of limp home mode was oil contamination of the electrical connector for the TPS. The connector is mounted on a bracket on the intake elbow just to the left of the throttle body. Try disconnecting it, flushing both halves with zero-residue electronic cleaner spray, allowing to dry, then reconnecting. If that makes no difference, it would be a good idea to remove the throttle body, drill drain holes in the plastic case of the throttle position sensor and flush it with electronic cleaner.
The Jag-Lovers forum XJ40 eBook has an excellent diagnostic procedure for LHM if the above doesn't resolve the issue.
Cheers,
Don
Cheers,
Don
Cheers,
Don
Lawrence (08-16-2019)
crazyac5
16
07-28-2012 04:26 AM
