XJ40 ( XJ81 ) 1986 - 1994
Suspension part
Old 09-24-2017, 08:14 PM
sejone63's Avatar
Default Suspension part
Hello I have a 1989 xj40 vanden plas. I noticed the other day when I was under it that my lower control arm crossmember was bent. I am having trouble locating another one. Can you help?
Old 09-25-2017, 04:09 AM
Robman25's Avatar
Hi this needs to be in the XJ40 thread. Can you post a photo to show the extent of the problem?
Old 09-29-2017, 05:24 AM
GGG is offline
Received 16,864 Likes on 12,186 Posts
Welcome to the forum sejone63,
I've moved your question from Mark V - X 420G to XJ40 forum. This is the place to post questions about your model.
Don B (09-30-2017)
Old 09-29-2017, 02:15 PM
frenchfairplaydriver's Avatar
good evening, on the diagram, what would be the twisted piece?
Don B (09-30-2017)
Old 09-29-2017, 02:18 PM
Don B (09-30-2017)
Old 09-30-2017, 10:05 AM
Received 13,206 Likes on 6,553 Posts
Hi sejone63,
It will certainly help us help you if you can answer frenchfairplaydriver's question about which part is twisted. Part 1 in the diagram he posted is the rear control arm or wishbone.
In the diagram below, Part 14 is the subframe (also known as the crossbeam or mounting frame). Part 1 in this diagram is the "wide mounting bracket."
A great place to find diagrams like this, as well as part numbers, is jaguarclassicparts.com, the parts service of the Jaguar Daimler Heritage Trust.
Parts like these are no longer available new from Jaguar, so salvaged parts are typically the only option, unless you can find new old stock. I try to find an eBay seller who is offering parts from the same model and year, and use the eBay message system to contact the seller to ask if he or she has the parts I need.
Cheers,
Don
MountainMan (10-10-2017)
Don B
General Tech Help
17
08-08-2017 09:11 AM
goodgame
10-21-2016 09:33 AM
MickJagguar
10-04-2016 04:26 PM
JimC64
02-13-2014 07:35 PM
bojangles
12-03-2006 09:07 PM
Quick Reply: Suspension part
