Talking alternator !
My beloved '94 XJ40's alternator is making a lot of mechanical noise on start-up. It makes the sort of noises that lead me to believe that the stator is loose on the shaft. When you rev the engine up to about 1500 rpm, it makes a short shriek, and then is perfectly fine until you shut it down again and another start from cold.
The belt is A-OK, tensioned properly, and the pulley isn't loose, runs fine and true.
Anybody ever ran into this? Thanks !
Best -
Jeff
Best -
Jeff
Received 2,266 Likes
jeffH (07-06-2012)
