Thump on braking 94 XJ12
Received 13,424 Likes
Hi alabassi,
There are many possible suspects for your thump: control arm bushings, ball joints, subframe Vee mounts and rear pivot bushings, wheel bearings, shock bushings, brake caliper guide pins and bracket mounting bolts, transmission mount (that noise usually comes from under your seat), rusted body mounting points, etc. It could be a serious safety issue, so you're going to have to take a good look at everything.
Cheers,
Don
Cheers,
Don
