Tires for 93 XJ40
Received 10,871 Likes
mdantonio95 (11-02-2014)
Received 12,933 Likes
You can use the aspect ratio calculator at the link below to determine the difference in rolling circumference between 225/65 and 225/60 tires to determine approximately how far off your speedometer will read if you go with the 225/60R15s:
http://www.tirerack.com/tires/tirete...141102044532:s
Alternately, you could consider 235/60R15s, which might increase tramlining slightly but probably shouldn't rub anywhere. Or, you could purchase as set of cheap used 16 inch wheels from an X300 and use 225/60-16 tires, which is what I'm running on our '93 (Yokohama Advan S.4., which is an excellent tire on a Jag saloon).
Cheers,
Don
The following 2 users liked this post by Don B:
93SB (12-07-2014),
I put a new set of 225/70-r15 tires on our red car,the ride is good,but they rub on the inside of the wheel wells when going over speed bumps.
In hindsight,should have gone with the 60 series tires instead!![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Our champ car calls for 205\70-r15 tires,and the feeling is a lot more sporty than Redd!
Hope this helps,
Jim
Hope this helps,
Jim
Yokohama Advan I am told is one of two tires currently manufactured that will tolerate the lateral force of a car that heavy and last. I originally had a set of Michelin Energy's that the lateral force of the car quickly ground the sidewalls into dust. I have now had the Advans for 4 years and they are terrific. They still look new with almost 20,000 miles on them. As Jeremy Clarkson would say, "these Jaguars are made of Wood, and Metal and Churches". Almost 5000 pounds worth...so make certain you buy shoes for your cat that wont disintegrate one day when going around a corner. Regards, Jeff
![Icon Tinykitball](https://www.jaguarforums.com/forum/images/smilies/icon_tinykitball.gif)
NTL1991
XJ40 ( XJ81 )
09-20-2015 06:22 PM
