torque settings
I think those torque specs are in the Haynes manual, which you can download here:
https://www.mediafire.com/?hx8bttsy4kxxr#3267xri9vx4v6
If you can't find them there, let me know and I'll look them up in the Jaguar Workshop Manual tonight - I have to run to a tennis date but I'll be back in a few hours.
Cheers,
Don
I think these are the specs you need (from the JDHT DVD Service Manual front suspension torque figures section):
Crossmember inner upper bolts 22-28 Nm
Crossmember outer lower bolts 24- 30 Nm
I know Jaguar calls the subframes "crossmembers," so these must be the specs for the upper Vee mount bolts and the rear lower pivot bolts, and they must be the specs I used because they're the only torque specs I can find for the crossmember.
Cheers,
Don
Cheers,
Don
93SB (03-23-2015)
Do I recall correctly that the nut is a Nyloc type? If so, the risk of it coming off is low.
aholbro1
08-05-2021 05:02 AM
chatmanx
09-11-2015 07:17 PM
