Tracking a hiss
Tracking a hiss
Not that I'm going to go nuts if I don't find it or not. Maybe someone else has had this issue and it was an easy find/fix.
Turning the climate control on there is a very slight hiss, on when the control is on. Is doesn't get louder if I increase the climate speed. Here is the kicker.
When braking into a corner (turning right) it goes away, then while applying gas to get back up to speed it starts again at that same constant slight hiss.
It sounds like its coming from under the dash passenger side. Almost like a vacuum issue. Just curious. I can live with it, but would rather not. Perry Mason?
It could be water in one of the blower housings from a clogged drain tube in the fresh air cowl area or climate control housing. I have seen broken 'squirrel cage' blowers from high water levels in the housing and the fan trying to turn in the water. If there is just enough water to touch the fan, then the noise will change with the water sloshing back and forth. The fan will rust and become inop after a while.
Just a thouhgt
bob gauff
Just a thouhgt
bob gauff
mrtalk, I reread your first post, I'm certain you are hearing the refrigerant. I don't know why, but the attitude of the car, turning, stopping etc., sure has an effect on the freon flow. I noticed it some in my '89 VDP, and even more in my '93 XJ6. An evacuate and proper recharge always reduced or eliminated noticing it.
Cheers,
blackenedindustries
09-30-2015 10:17 AM
