XJ40 ( XJ81 ) 1986 - 1994
TRW mineral oil vs. Pentosin CHF
Old 07-01-2016 | 01:32 PM
Hagered's Avatar
Default TRW mineral oil vs. Pentosin CHF
Hello all,
I have an 88 xj6 and my hydraulic fluid for the booster and ride levelling has run low. I was wondering your thoughts on draining the reservoir and using Pentosin CHF fluid rather than TRW as I live in Canada and that stuff is hard to find here and I Would rather not pay the 60 dollars for a litre of the stuff to order it off amazon or ebay.
Old 07-01-2016 | 10:21 PM
motorcarman's Avatar
If I had a 1988/89 XJ40 and need hydraulic fluid I would probably opt for Pentosin CHF 7.1 Mineral Oil.
http://www.pentosin.net/pressrelease..._CHF7-1_V2.pdf
The CHF 11S is synthetic but the CHF 7.1 is regular mineral based.
I do remember when I went to A&P school 30 years ago we used Mil Spec 5606 that was RED but smelled EXACTLY like the Castrol 5966 fluid.
bob
Don B (04-05-2017)
Old 07-02-2016 | 12:22 AM
frenchfairplaydriver's Avatar
Hello, I own a 1989 XJ40, with SLS suspension, I use the Citroën LHM fluid that is well suited
Best regards
Old 08-24-2016 | 12:17 AM
British Ride's Avatar
I have bought several 500ml containers from the local Jag dealer for $16CDN ea. Have you checked the dealer?
Old 10-29-2016 | 08:10 PM
shtekler's Avatar
Default Castrol Mineral oil
bob
My recommendation to you check very carefully that the new oil will not harm the seals
harvest14
01-08-2017 04:03 PM
Paulo Santos
05-03-2016 09:49 AM
British Ride
XJ40 ( XJ81 )
05-01-2016 06:47 PM
Scottsgreenjag
04-14-2016 02:40 PM
tai4de2
04-05-2016 03:56 PM
Quick Reply: TRW mineral oil vs. Pentosin CHF
