Underscuttle pad and pad plate fit
Another problem I have is the passenger side underscuttle pad and the steel plate behind it.
I can't get the plate remounted after removing it. What am I missing? The lower right hand corner
won't return to its position, (actually both lower corners). Is it possible something else has moved out of position?
I'm at the point where I'm either not going to use it or bend up the corners (last resort), any ideas?
Thank you,
Roger
Thank you,
Roger
Received 13,203 Likes
I can't remember our '88 having a steel plate behind either underscuttle, but I'm fairly certain that our '93 only had a steel plate on the driver side. Is it possible that's where your steel plate goes?
Cheers,
Don
The following 2 users liked this post by Don B:
93SB (01-23-2021),
MountainMan (02-01-2021)
The following 3 users liked this post by Roger95:
