Vacuum Hose for AC Controls
I was in the process of inspecting and cleaning the connectors for the various components under the passenger side dash.
I remember disconnecting the vacuum line shown in the included photo.
After putting all of the connectors back together, I cannot for the life of me figure out where the vacuum line goes.
All of the other vacuum lines are intact as I never disconnected them
vacuum line coming/going into center console
I remember that the connection point was somewhere within the tangle of wires down there.
Can anyone take a look and tell me where the connection point for this line is?
After posting the above due to frustration, I went back under the passenger side dash and removed the relay panel for the 3rd time searching for the connection point for the vacuum line.
Apparently the connection point, a vacuum hose was snagged up and above the relay panel.
So, problem resolved.
The reason I went under there was to clean up all of the connectors and to see if there was any apparent corrosion at the connectors due to some issues I am having with the car.
1. Transmission not shifting
2. No hazard and turn signals.
Don B (08-17-2019)
denraden1
06-30-2013 01:04 AM
