XJ40 ( XJ81 ) 1986 - 1994
VDP flashing bonnet (hood) lights and tail lights also won`t start
Old 05-30-2014, 10:15 AM
chitownred's Avatar
Default VDP flashing bonnet (hood) lights and tail lights also won`t start
hay y`all.
I have a 91 VDP flashing bonnet (hood) lights and tail lights also won`t start.
any thougts?
Old 05-30-2014, 10:22 AM
Rob Evenson's Avatar
chitownred,
Love to help, but, your description is way too vague...... detail please...
Bonnet lights.... you mean the ones on the underside of the bonnet that illuminate the engine bay when the bonnet is up.....?
Won't start..... ? What's it doing....describe.
Are there any codes on the VCM?
chitownred (05-30-2014)
Old 05-30-2014, 11:32 AM
chitownred's Avatar
hi at first thought it was a fuel pump problem tested same it`s not it.
yesterday left line disconnected it was working then stopped?
alarm maybe?
Old 05-30-2014, 12:47 PM
What "line" are you referring to.... battery cable, fuel supply....????
Is the engine cranking, but not engaging.....????
Do you get nothing when you turn the key....??? No noise, just a clicking sound...., or nothing at all...
Describe in detail, when you turn the key...... what happens..... describe the behavior of the car when the key is engaged.
alarm maybe?
Old 05-30-2014, 12:52 PM
chitownred's Avatar
hi fuel line it cranks shot of starting makes it fire.
changed strainer.
right taillight blinking as well underhood lights.
cranks just fine.
Old 05-30-2014, 01:14 PM
Roger95's Avatar
Low battery, security system? These cars get screwy when the battery charge is low.
Put a DVOM on the battery and check the charge.
Old 05-30-2014, 01:53 PM
chitownred's Avatar
hi charging battery now.
Old 05-31-2014, 07:37 AM
chitownred's Avatar
new info dash lights and all marker lights as well?
Old 05-31-2014, 08:20 AM
Roger95's Avatar
Try pressing your remote 5 times in quick succession. Sounds to me like your security system could be acting up because of a low battery charge.
Old 05-31-2014, 08:40 AM
chitownred's Avatar
don't have remote
Old 05-31-2014, 08:48 AM
Roger95's Avatar
You will have to have it reset at a service facility that has a Jaguar scan tool. The security systems and ECUs in these cars are becoming increasingly troublesome as the cars age.
One of my research projects is finding modern replacements for them.
Old 05-31-2014, 10:03 AM
chitownred's Avatar
could the aftermarket radio be a factor?
Old 05-31-2014, 12:05 PM
Short answer...yes.
Problem is the lack of security system schematics for pre-93 MY's. I have not been able to locate any wiring diagrams for my '89 equipped with the security system. Most of the early MY's were dealer installed systems, (Jaguar equipment), but no wiring diagrams, at least not made publicly available.
I'm sure somebody has one, hope they show up soon, I want to upgrade my radio, but won't until I have the proper mapping to ensue no problems.
If I'm not seeing something.... somebody.... speak up!!!
chitownred (05-31-2014)
Old 05-31-2014, 12:29 PM
Roger95's Avatar
Rob is correct; aftermarket radios can and will cause problems with the security system. Another point I'd like to add to my earlier advice; if you know someone who would be willing to let you use their key fob or you buy a used one you should be able to use that to shut off the security system - click it 5 times.
Old 05-31-2014, 02:17 PM
chitownred's Avatar
I just talked a service manager at dealer, he said fob are coded to one not universal.
Old 05-31-2014, 02:23 PM
Roger95's Avatar
To be sure, but you should be able to recode one to your car.
Lawrence (05-31-2014)
Old 05-31-2014, 04:27 PM
chitownred's Avatar
I`m gonna se if the dealer will tell me where the valet switch is.
Old 05-31-2014, 05:12 PM
It should be under the center armrest cover, it's a toggle switch. I don't think that will help you. I'm not sure about a '91, but I think you either have to use the fob to reset, or enter the security code via the original radio. The CPU needs the input in order for it to know all is well.
You might want to enter a post in the section orientated towards Audio/Visual and see if anyone has a fix for you.
Another option, though I have never performed the task, is what is refereed to as a "hard re-boot or hard boot" (I think) in resetting the CPU. Research the forum archives for how to accomplish this task. Personally, I would never do this, seems the risk out weighs the reward, but I have read people have done so. Research before you do it. I do not know if it would work or not. I've clearly stated my position on it. You wold be doing so at your own risk.
Advice for the future, thoroughly research the forums before you do any modifications to these vehicles. Most people would advise against drastic mods to the electrical systems on these cars. Radio conversions have been done, but I don't recall anyone having the issues you are experiencing, unless of course they didn't report the problem.
Good luck.
Old 05-31-2014, 06:10 PM
Roger95's Avatar
The hard re-boot is where (if I'm correct) you remove the negative (-) battery terminal from the battery and briefly (very briefly) touch it to the positive (+) battery terminal and then reconnect it to the negative terminal. I have never spoken to anyone who has ever done this.
Old 06-01-2014, 10:02 AM
chitownred's Avatar
This car had interlock at one time. Just wondering if that might be a factor?
Quick Reply: VDP flashing bonnet (hood) lights and tail lights also won`t start
