warning indicator light
RE: warning indicator light
I have an '88 XJ6 and the light you might be refering to is the warning light for low mineral oil in the brake system. The brake system power assist is under pressure with fluid not vacuum
" Green Jag Juice" is available at any foriegn auto parts store and runs about $10 for a small container( @ pint or 2).
Rayray, click on my screen name and send me a PM if you want a set of owners handbooks for your car. Frankie is exactly right, and you need mineral oil before you lose brake assist. You're not gonna be happy when you have to fix the leak, but that's another question for another day.
Geo, there is a different warning he would be seeing for "low brake fluid" if that were the case.
