weird issue with fuel? 1993 xj6
Rob:
Two things... First, I wouldn't let the fuel get that low! It's that whole, 'Doctor, it hurts when I do this' kinda thing. Second, at least it is starting; but could this be the beginnings of a fuel pump no longer able to keep the pressure up? Next time the gas is that low, I'd do the 'key cycle' check. Cycle the key through positions I and II (but not starting) three times or so to give several priming bursts, and see if the car starts on the first crank. Otherwise, it might be time for a fuel pressure check at the fuel rail.
Scott
Scott
malibudav (12-29-2011)
No one knows better than I, that cars can't run on water. As a matter of fact the entire system takes a beating when trying to. First thing I do when getting a 89-94 XJ6 is climb under and look at the fuel pump. Even if it works, if it looks old to my eyes I am changing it. The job itself doesn't take long, and fuel pumps are short money.
Rob:
Scott
Scott
Thanks for the knowledge!
malibudav:
I was referring only to the checking of fuel pressure. I'm not really familiar with a check valve in this system; and (thankfully!) I've not yet had to replace my tank canister and pump - so I've not had to deal with it. I cannot access my shop manual presently because it only runs on a computer that I currently have in storage. I've looked at the Haynes manual (pg 4-5), which doesn't say anything about a check valve or it's replacement. Perhaps others will chime in. Sorry!
Scott
Scott
The last time I had my in-tank pump replaced, I was still losing pressure and was told it was a failing check valve. I dealt with it by cycling the ignition to get the .5 second bursts and then it would start.
I called coventry west and IIRC they told me this part was no longer for sale but he did identify the part.
Chet Ramnarain (bozzner)
09-03-2015 01:21 PM
