XJ40 ( XJ81 ) 1986 - 1994
Wet Carpet
Old 01-16-2017, 10:10 PM
Received 13,427 Likes on 6,625 Posts
Excellent work, Larry! Anxiously awaiting your next report!
Old 01-18-2017, 09:23 PM
Lawrence's Avatar
Received 1,871 Likes on 1,192 Posts
Well it p***ed down last night - however - this morning there was no cup of water in the footwell, so PROVISIONALLY let's say it's fixed
There's still residual damp in the surrounding underlay and carpet edges so I suppose it might take a while for everything to get back to bone dry ..when it does, I'll commit to the problem being solved - but for now, hesitant to do a "definite"
In the meantime, I'll keep the old rubber mat in there ...easy to lift it up and check if the footwell stays dry ...no point putting the carpets and underlay back if it isn't completely fixed, eh?
All in all though, I'm tentatively happy
Larry
The following 2 users liked this post by Lawrence:
93SB (01-21-2017), Don B (01-18-2017)
Old 01-18-2017, 10:09 PM
Excellent, Larry! Your great detective work and photos will no doubt help many of the rest of us in the future.
Cheers,
Don
Old 01-19-2017, 07:18 PM
95Leaper's Avatar
It might help using a blow dryer or heat gun to dry that remaining dampness. Sounds like you cured the problem!
Old 01-19-2017, 08:45 PM
Lawrence's Avatar
Sounds like an idea - do you have a generator or a 500ft extension cord I could borrow?
Larry
Old 01-19-2017, 09:11 PM
Maybe set a large pan of uncooked rice or cat litter in the car to absorb the moisture?
The following 2 users liked this post by Don B:
93SB (01-21-2017), MountainMan (02-07-2017)
Old 01-19-2017, 09:20 PM
95Leaper's Avatar
I wonder if your leak issue is partially due to the climate change up there. Possibly the rubber may shrink somewhat due to the cold weather. We get some pretty heavy rainstorms at times here in Florida and I'm somewhat surprised I've never gotten any kinds of leaks of any kind.
  #28
plums's Avatar
Received 2,185 Likes on 1,625 Posts
On the X308 both drains have hoses on them that run down and
are left loose in the fender well.
(NOT SO) funny thing is that if one examines the fender liners there
are two holes that can be punched out and moulded hose retainer clips
adjacent to the holes in just the right place to hold hoses going through
the holes.
If the two holes are punched out, the hoses can be run to the exterior
and have a bit of slack to clip into the retainer clips.
My conclusion is that either using the holes interfered with tea breaks,
or a cost cutting "engineer" decided saving a couple of minutes on the
assembly line was worth creating a rust trap for the future owner.
Mine now drop the water just behind the front tires outside of the fender
liner .... as originally intended despite the attempt of the two groups
of fools that tried to derail the original intent.
Don B (02-04-2017)
Old 02-04-2017, 08:14 PM
Lawrence's Avatar
Default Update3
Ok, well it's been about 3 weeks since I did the drain channel modification and I finally got all the residual wet areas around the perimeter dried out completely.
It's been pretty good in the weather dept for the last little while but night before last we had another rain/sleet storm that lasted for a few hours with a steady downpour, so really the first REAL test of the modification.
Happy to report that this morning the footwell was bone dry and can now confirm the repair/modification is a success.
I advise all owners to do the same thing next time they open up the fender liners as all cars are going to leak here eventually.
Larry
The following 6 users liked this post by Lawrence:
93SB (02-07-2017), Don B (02-04-2017), jerry_hoback (02-05-2017), Kay (02-05-2017), littlelic69 (10-02-2018), MountainMan (02-07-2017) and 1 others liked this post. (Show less...)
  #30
Old 02-05-2017, 12:43 PM
jerry_hoback's Avatar
Received 1,164 Likes on 817 Posts
Excellent news!
