XJ40 ( XJ81 ) 1986 - 1994
What ecu is behind the glove box
Old 07-03-2009 | 10:22 PM
1988xj6navy's Avatar
Default What ecu is behind the glove box
There is a ecu behind the glove box that is rusted I feel that it is causing all my shorts in my car. What ecu is this is this the main one and what does it do. This isnt mine this is a photo of a new one mine is rusted and looks to have water damage. Any help would be welcomed.
Old 07-03-2009 | 11:40 PM
ArmyJag's Avatar
looks to be the engine management if memory serves, it will have something like number-cux on it.
Old 07-04-2009 | 01:17 AM
JagtechOhio's Avatar
Default That's the CPU
It mounts behind the glovebox, offset toward the center of the car. One pozidrive screw in the top slot, two on the bottom to retain it to its' mounting bracket.
This unit controls various accessory fuctions: clock, antenna timer, interior light sequencing to name a few. PM me if you want a good used one and don't want to get robbed for it.
Old 07-04-2009 | 01:30 AM
Well it apears that water leaked on it at sometime there was rust all on the outside of its case. I cleaned it up and got the shorts in the lights to go away but will need a new one when i get money. Would this cause the fuel pump to burn out or act crazy.
Old 07-04-2009 | 06:51 PM
Hey Bill,
PM me with an address. The manuals came back to me from your Post Office as unclaimed. Hope all is well.
Navy, I don't think the CPU affects the fuel pump circuit. The fuel pump relay should energize when the ignition is on, and click again after about two seconds when it is de-energized. I'd have to look at a diagram to see if this timing is controlled by the CPU and not the ECU.
Locate the pump relay, underdash RH side, and see what you have with a test light.
I had an '88 or '89 come in many years ago that had a resistor plate wired in series to the pump, and located under the rear seat cushion. That's where there is a connection to the link lead which goes out to the pump. There was no power out of the resistor. The big mystery was what in the hell it was there for: Jaguar didn't show the component, and I have never seen one on any other XJ40.
By the way, thanks again to both of you for your service to the United States of America on its 233 birthday !!
Old 07-05-2009 | 01:53 AM
i FOUND IT it was the rubber caps on the fuel pump conectors dried out. The pos one was grounding out the fuel pump on the metal. The rusted box still causes a few probs I got took it apart and got it to work ok. But i will have to get a new one soon when i get money to.
JaguarLover101
48
06-12-2023 11:28 AM
jluckcuck
11-06-2015 08:49 AM
Johncy2000
10-02-2015 02:05 AM
pnwrs2000
09-30-2015 02:56 PM
Quick Reply: What ecu is behind the glove box
